Књиге за преузимање - џабе
Postod Bjeli » 03 Jul 2006, 10:20
1 - Basic Mechanical Skills
2 - Tapping Bottom-Bracking-Shell Threads
3 - Facing the Bottom-Bracket Shell
4 - Reaming and Facing the Head Tube
5 - Milling the Fork Crown
6 - Sizing and Threading Fork Columns
7 - Seat-Tube Milling
8 - Frame and Fork Alignment and Damage
9 - Adjustable Bottom Brackets
10 - Cartridge-Bearing Bottom Brackets
11 - Headsets
12 - Adjustable-Cone Hubs
13 - Cartridge-Bearing
14 - Adjustable-Cone/Cup Pedals
15 - Cartridge-Bearing Pedals
16 - Wheel Building and Rim Replacement
17 - Wheel Truing and Repair
18 - Wheel Removal, Replacerment, and Installation
19 - Tires and Tubes
20 - Taper-Fit Crank Arms
21 - Cottered Crank Arms
22 - One-Piece Cranks
23 - Chainrings
24 - Pedal Removal, Replacement, and Installation
25 - Freehub Mechanisms and Thread-On Freewheels
26 - Chains
27 - Chainline
28 - Handlebars, Stems, and Handlebar Extensions
29 - Seats and Seatposts
30 - Shift-Control Mechanisms
31 - Derailleur-Cable Systems
32 - Rear Derailleurs
33 - Front Derailleurs
34 - Brake Levers
35 - Brake-Cable Systems
36 - Cable Operated Rim-Brake Calipers
37 - Hydraulic Rim Brakes and Disk Brakes
38 - Suspension Forks and Rear Shocks
лозинка:
Kod: Obeleži sve
uploaded-by-the-onlyone
преузми:
Kod: Obeleži sve
http://rapidshare.de/files/15689815/TBMOBRepair.rar
Bjeli
Postovi: 5
Pridružio se: 16 Apr 2005, 13:18
Postod Bjeli » 03 Jul 2006, 10:26
63.62 МБ | педеф | ISBN 091457809X | 593 стране
лозинка:
Kod: Obeleži sve
Dr.Kimble@RapidShare
преузми:
Kod: Obeleži sve
http://rapidshare.de/files/22847432/THSFBMechncs.rar
Bjeli
Postovi: 5
Postod mixitron » 03 Jul 2006, 12:10
Bravo majstore :)
Jel' Barnett onaj pdf od 11 mega?
mixitron
Postovi: 528
Postod Bjeli » 03 Jul 2006, 21:27
mixitron je napisao:Jel' Barnett onaj pdf od 11 mega?
Да.
Bjeli
Postovi: 5
Postod marin » 05 Jul 2006, 11:36
Kako to skinuti?
Molim pomoc.
marin
Postovi: 34
Pridružio se: 14 Okt 2005, 09:21
Lokacija: Knjaževac
Postod Bjeli » 05 Jul 2006, 12:36
1. отвориш нови прозор
2. у поље за адресу препишеш (умножиш, па убациш) адресу из поља "Код", испод ријечи "преузми:"
3. потврдиш (Enter)
4. кад учита страницу, спусти на дно табеле, и притисни на дугме "Free"
5. пошто учита нову страницу, у неком од редова, одбројаваће до приказа насумично направљене слике са три карактера (само слова, или само бројеви, или мијешано)
6. упишеш та три карактера у поље десно од слике и потврдиш
7. потом ће се отворити нови прозорчић који ти нуди да снимиш (сачуваш) ту датотеку - потврди
8. сачекај док се преузимање заврши (од пар минута, до пар сати за оне који имају обичне 56кб модеме)
Bjeli
Postovi: 5
Postod sidarta » 05 Jul 2006, 16:36
...imam problem sa skidanjem druge knjige koja ej teska 60mb... kao freeuser rapidshare-a postoji limit od 30mb po satu... tj tu knjigu ne mogu da skinem ... ako je neko skinuo i ako je voljan da mi je posalje evo moje e-mail adrese :sidarta83@gmail.com pa da se dogovorimo...
hvala unapred...
Nikola
sidarta
Postovi: 19
Pridružio se: 04 Jul 2006, 14:15
Postod Bjeli » 05 Jul 2006, 16:58
То ограничење важи за одређени број сати (минута) након преузимања неке од датотека. Како је случај да је књига "тешка" 65 МБ, потребно је да сачекаш рецимо сат и по након преузимања Барнетове књиге од 11 МБ, и поново кренеш са преузимањем.
Bjeli
Postovi: 5
Postod sidarta » 05 Jul 2006, 21:04
Problem je u tome sto ja sacekam... (vec sam radio sa rapidsharom) i dobije tkz ticket reserved.. pocnem download.. ali download stane na 30 mb.... i nece dalje... u to me je problem
sidarta
Postovi: 19
Povratak na Čekićara
